July 27, 20233 yr An example of an error message I get with the CSV is this: file could not be parsed. (CSV file is missing expected headers: url, username, password, timeCreated, timePasswordChanged) Meanwhile, attempting to import the JSON tells me that the file is empty, even though it is not. It seems right now that I am unable to import my Enpass vaults into other managers. Does anyone know of a fix for this?
July 28, 20233 yr This is due to the nature of the file's internal phrasing. Every manager has different options on how the export and import. You would either have to manually edit the .csv or .json to fit it to the format of your destination OR tell the destination the correct definition of your .csv/.json file.
July 28, 20233 yr Hi @LionGuy82 Please provide the version of the Enpass app, operating system, and password manager you are using for importing the CSV and JSON files. I'll be more than happy to investigate this matter for you.
