October 13, 20233 yr Hello, I just tried to create a passkey for the Gemini app on iOS and an error comes up. Not sure if the issue belongs to Enpass or Gemini, but thought I would report it here just in case. Also interested to see if anyone else is experiencing something like this, be it with Gemini or any other apps. Image attached below. Edited October 13, 20233 yr by Scarce Noodle Grammar
October 13, 20233 yr Hi @Scarce Noodle Please share the version of the Enpass app and iOS you are using and I'll get this concern checked for you.
October 13, 20233 yr Author 2 hours ago, Abhishek Dewan said: Hi @Scarce Noodle Please share the version of the Enpass app and iOS you are using and I'll get this concern checked for you. Hi @Abhishek Dewan, I’m using Enpass 6.9.3 (776) on iOS 17.0.3. My Gemini app is running version 23.10.10.0 build 36132, just to be thorough. Thank you!
October 16, 20233 yr Hi @Scarce Noodle Thank you for sharing the requested details. Our development team was able to replicate similar concerns related to creating Passkeys on iOS apps and they are now working on fixing it. As soon as a patch addressing this issue is released, I will be sure to update this forum. Kindly bear with us until then. #SI-3492
October 16, 20233 yr Author 1 hour ago, Abhishek Dewan said: Hi @Scarce Noodle Thank you for sharing the requested details. Our development team was able to replicate similar concerns related to creating Passkeys on iOS apps and they are now working on fixing it. As soon as a patch addressing this issue is released, I will be sure to update this forum. Kindly bear with us until then. #SI-3492 Great news, thanks for the update.
