January 7, 20242 yr it just keeps circling. Its actually easier to delete the whole data on iOS and re-initiate as new. MacOS 12.7.2 Enpass 6.9.3 _ iOS iphone 16.7.2
August 11, 20242 yr Author This is still not fixed. It just keeps saying "Sychrnozing" forever. I have to re-install enpass to make it work again. Same issue on iPad. macos 12.7.6 iphone ios 17.6.1 enpass latest
August 13, 20242 yr I'll quickly ask the Technical Team to look into this and share their findings with you. I'll keep you updated on any developments. Enpass thanks you for your support and patience regarding this issue. #SI-3946
August 30, 20242 yr It seems that you might be using an older version of Enpass on your Mac. Please update the Enpass app to the latest version and check if the issue persists. If the problem continues, kindly share the following information: Are you experiencing this issue in any specific scenarios, such as when waking up your system from sleep or any other particular situation? The number of items and attachments in your vaults. Your feedback will help us investigate the problem further. Thank you for your cooperation!
