June 1, 20188 yr Hi there, I am thinking what was your idea of putting the backup is such UNUSABLE format of the FOLDER names? it is not possible to use it in any script, not even in "sort by name" ok, by date maybe but still - I have not seen it in ANY system filename I understand: text + time + VERY USEFUL INFO (I am serious - very useful) but folder name?
December 10, 20187 yr Author As a user who paid for this software I would expect any answer, even with some delay if not crucial topic but 5+ months with no reaction? hmm...
December 11, 20187 yr Hey @zyghom, Skipping this thread was just an oversight. Sorry for that. We have already improved this and will be available in the next major update( Enpass 6). If you are willing to try the beta version you can download it from our website. Cheers!
December 12, 20187 yr Author On 12/11/2018 at 10:41 AM, Anshu kumar said: Hey @zyghom, Skipping this thread was just an oversight. Sorry for that. We have already improved this and will be available in the next major update( Enpass 6). If you are willing to try the beta version you can download it from our website. Cheers! thank you Anshu, appologies accepted - backup works much nicer way ;-) So I am testing 6.0 on macOS (on Android already some time back) and the things are: - previously timeout for entering password/pin/touch was counted since last usage of Enpass - now it is counted since you stop using your computer - is this only me who realised this or this is as per design - a new feature? and probably this way is even better - the timer does not start as long as you work (maybe this could be configurable?) - on Firefox - no issues, great job - on Safari - cannot install it - newest Safari is 12.xx and your extension is till 11.xx only - what now? see the pictures attached - THAT IS A NO GO for using it on MacOS. IT IS WORKING Edited December 12, 20187 yr by zyghom working on Safari 12.xx as well - no idea why it was not before ;)
