May 15, 20242 yr Hello, I have Enpass on Linux desktop and my folder sync errors every day. Quote Sync Error: Destination Folder for sync unreachable I always have to disconnect the folder and resync again. This is a huge pain point currently. This used to work very stable for years (I never used any other sync mode.) ~ ❯ uname -a Linux intan 6.8.8-arch1-1 #1 SMP PREEMPT_DYNAMIC Sun, 28 Apr 2024 15:59:47 +0000 x86_64 GNU/Linux ~ ❯ pikaur -Qs enpass local/enpass-bin 6.10.1.1661-1 A multiplatform password manager I don't understand the reason. This folder is a local folder on my hard disc. How can this be "unreachable?" Please help!
May 15, 20242 yr Author When I go to vault settings and click "Sync Now," the same issue shows. Disconnecting and reconnecting does not resolve this.
May 17, 20242 yr I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them. #SI-3840
May 20, 20242 yr Author Thank you. I can confirm this issue across all my Linux devices. I sync them with an Android phone which does not have any issues with the folder sync.
June 17, 20241 yr Author I solved it: Apparently, the synchronization does not only apply to the vault but also the settings. So having different sync-paths on different desktop devices caused an issue always looking for the sync data in a non-existing location. To solv this, I had to set it to the same path on all desktop machines. It's kind of weird though.
