Wifi sync stop working
I have problem with wifi sync of my vault.
I have Mac Catalina 10.15.7, Enpass version 6.11.2
I click to start server, click to vault and qr code is created, but when i scan it, it wrote no vault.
Also the manual sync information are not usefull because the varification code is different.
I also see that the server has no port.
The Enpass wrote in corner: Synchronization faild - Target folder for synchronization is not reachable.
It did work before. I did not install anything new, just system updates.
I check firewall, access to the disk or folders.
I dont have the wifiyncserver_bin in mac firewall, only Enpass app.
I thing the server did not start. Can you help me with that?
Edited by Jenda
ok. I stop sync server. Go to the Enpass app content and find the file wifisyncserver_bin and run. Then go to Enpass app and start server again. Now there is port and sync start working.
Ok. The problem still persist, the message. "Target folder..." is still there and the mobile device dont see the vault.
Any help?
We would suggest you disconnect the Wifi-Sync server from the connected devices and set it up by following the steps in the link - https://www.enpass.io/wifi-sync/ , or manually by following the steps in this link - https://www.enpass.io/wifi-sync-manual-setup/  .
If you have any additional questions or require further assistance, please mail us at support@enpass.io
I stop the server
and run the server.
But you can see the error message appears immediately.
So I remove the vault.
Stop and start the server again.
no error message
Then scan the code -> error
Manual set-up. but there is no verify code and there is again the error message with the transfer vault to sync folder
Edited by Jenda
