Autogenerated passwords are being flagged as "weak"
I've noticed on two separate occasions when autogenerating a password in the desktop version 6.11.9 (1915), Enpass tells me the password is not strong enough to be secure. I would think that since your software generated the password, it would have a secure template built in. Otherwise, what's the point of using your autogeneration tool?
We understand your concern. Enpass allows users to customize the password generator settings based on their security preferences. You can adjust the password length, complexity (uppercase, lowercase, numbers, symbols), and other parameters to ensure it meets your desired security level.
By default, Enpass generates strong passwords, but if a specific policy requires a higher strength, you can modify the settings accordingly.
  • 1 year later...
I think my point was that I was using a password autogenerated by Enpass. And then Enpass told me it was not strong enough to be secure. Just one of those head-scratching moments, but thanks for getting back to me. Not sure why I never saw this previously.
