May 3, 20251 yr Using https://mysite.signin.aws.amazon.com/console with Premium Enpass. It recognizes that the site can take a passkey, but when I try to create it, it takes me to the normal Amazon site instead of AWS. If I try to do this on the AWS end, it doesn't work either. If I try to setup a passkey, it fails, and 2FA doesn't work either.
May 12, 20251 yr I’ve forwarded your request and the details of the issue to our Enpass Product Team for further investigation. They will look into the behavior you're experiencing with the AWS sign-in flow and passkey setup. #SI-4356
May 28, 20251 yr Our team is currently investigating the issue where clicking the "Create Passkey" button for the AWS item redirects to the regular Amazon site. This issue is being actively reviewed, and we will provide updates as we make progress. In relation to the second issue concerning difficulties with setting up a passkey or enabling 2FA in the AWS console, we kindly request the following details: A screen recording that captures the issue Browser name and version Enpass app version Extension version
