July 23, 20251 yr Enpass iOS seems to default to the Primary vault for the autofill widget in Safari. I have four vaults and want to default to 'All vaults'. I have to manually select all vaults every time the autofill opens. If I open Enpass app then all vaults is the default. Enpass iOS 6.11.12 (1002) iOS 18.5
July 25, 20251 yr To make All Vaults the default view when using Autofill in Safari on iOS, please try the following steps: Open the Enpass app on your iOS device. Navigate to Settings > Vaults. Tap "Always Open To". Select "All Vaults" from the list. This should ensure that whenever the Autofill prompt appears, it defaults to showing items from all vaults instead of just the Primary vault.
July 25, 20251 yr Author It was already set to 'All vaults'. 'Always Save Items to Vault' is however set to 'Primary'. So either that setting applies to autofill and not just saving, or there is a bug.
July 28, 20251 yr To investigate this further, please raise a ticket by emailing support@enpass.io and include a screenshot of the current settings where "Always Open To" is set to "All Vaults." This will help the team verify the configuration and check if there's a possible bug affecting autofill behavior.
November 24, 2025Nov 24 On 7/25/2025 at 2:06 PM, Amandeep Kumar said: To make All Vaults the default view when using Autofill in Safari on iOS, please try the following steps: Open the Enpass app on your iOS device. Navigate to Settings > Vaults. Tap "Always Open To". Select "All Vaults" from the list. This should ensure that whenever the Autofill prompt appears, it defaults to showing items from all vaults instead of just the Primary vault. Thank you for sharing
April 13Apr 13 Author On 11/24/2025 at 3:03 AM, SarahAPetersen said:Thank you for sharingThanks but that is not working.
