July 27, 20251 yr I notice weird issues on some websites I vist. Random javascript based behaviour will not work when Enpass extension is enabled As soon as I disable Enpass then the behaviour works as expected. Here is one example: https://www.shelly.com/de/products/shelly-blu-gateway Going to this website without Enpass you can click the thumbnails to replace the main photo. When Enpass extension is enabled this is not possible. Adding the domain to skipped domains in Enpass extension does not make a difference. I have to disable Enpass extension in Safari for the website to work properly. Enpass 6.11.12 (2002) Safari 18.5 (20621.2.5.11.8)
July 29, 20251 yr I've shared the details with our Technical Team to investigate the unexpected JavaScript behavior on certain websites specifically the thumbnail interaction issue on shelly.com when the Enpass Safari extension is enabled. We'll look into this further and share any findings here. If additional information is required, we’ll reach out via this thread. SI-4439
July 31, 20251 yr Thank you for allowing us the time. For us to better understand the issue, could you please share a brief screen recording demonstrating the problem? It would be helpful to see what happens on the Shelly website when the Enpass extension is enabled vs. when it's disabled. This will allow us to exactly understand your experience and help our technical team in effectively investigating the problem. Note: You may share this with the support team at support@enpass.io. Thank you! SI-4439
July 31, 20251 yr Author I made a post about the same issue some time ago as well, I believe it is the same issue: https://discussion.enpass.io/index.php?/topic/31826-primary-vault-is-always-selected-when-opening-enpass-autofill-widget/#comment-92249
August 1, 20251 yr @Sleepyhead We’ve received your request and the video you shared thanks for taking the time to send that in. Our team will review the details and get back to you as soon as possible.
