July 30, 20251 yr When refreshing the Enpass repo on OpenSUSE Tumbleweed, I get a "Signature verification failed" message (see attached screenshot). I tried removing the repo and adding it again but still had the same issue.
July 31, 20251 yr Thank you for flagging this issue and I've shared the details with our Technical Team to investigate the signature verification failure on OpenSUSE Tumbleweed. We are now looking into the issue and will come back with updates/answers soon. For additional information we might require, we’ll follow up via this thread. #SI-4443
August 2, 20251 yr I have got the same issue and tried to see if the following helped (it did not): Remove the Enpass repository Download the key from Enpass Compare it with the key I already had. It was the same Add the Enpass repository I was still with the same error as mentioned in the OP.
August 4, 20251 yr Thank you for sharing these additional details. This information will be helpful for our technical team as they continue to investigate the issue. We will keep you informed as soon as we have any updates on this.
August 6, 20251 yr Experiencing the same issue - Signature verification failed for repomd.xml If you want to update the rest of your system you can temporarily disable the Enpass repository on OpenSUSTE using YaST. From the "start" menu look for YaST Software Repositories Find Enpass, and uncheck "Enabled" at the bottom left Press OK Attempt to redo sudo zypper dup and you should be able to go through with the other updates
August 8, 20251 yr I'm suffering from the same issue (SuSE Tumbleweed). Would be nice to see a solution soon as I can't update Enpass anymore. I'm currently on v6.11.6.1833, while the current version according to your website is 6.11.12.1953 (released July 28th, so the error message seems to be caused by this update). Regarding enabling/disabling the repository: this can also by done using the CLI: ~ $ sudo zypper mr -d Enpass Repository 'Enpass' has been successfully disabled. ~ $ sudo zypper mr -e Enpass Repository 'Enpass' has been successfully enabled. Alternatively you can get a list of all repositories using zypper -lr and use the number of the Enpass repository instead of its name.
August 11, 20251 yr We’re glad to know that the latest release has resolved the issue for you. Thank you for confirming this on the thread, your update will surely help other users facing a similar problem. If you encounter any further issues or need assistance in the future, please feel free to reach out.
