July 31, 20251 yr Can I change the connection from the WiFi server to Nextcloud in a vault? If not, how can I transfer all data, categories, and templates to a new vault?
August 1, 20251 yr Yes, you can change the sync method for a vault from Wi-Fi to another cloud service like Nextcloud. To do this: Open Enpass and go to Settings > Vaults. Select the vault you want to modify. Tap or click on ‘Disconnect’ under the current sync method. Then select ‘connect’ again and choose Nextcloud. Enter your Nextcloud credentials and complete the setup. This will retain all your existing data, categories, and templates within the same vault no need to create a new one.
