May 26May 26 Hello Enpass Support Team,I would like to report a bug that has been occurring for several months across multiple Apple devices.My EnvironmentEnpass Pro / Lifetime license (I was upgraded from the former free version to a free Lifetime license years ago)Devices:iPhone 17 ProiPhone 15 ProiPad AirOperating systems and apps are up to dateBrowser: mainly SafariThe issue occurs both in Safari and inside appsProblem DescriptionThe problem happens especially when using Passkeys.When I try to log in to a website or app (for example PayPal), the corresponding Passkey is often not shown in Enpass. Even if I manually search for the entry, it does not appear.At the same time, Enpass frequently displays the following message:“Upgrade to PremiumIn Lite mode, Enpass can store up to 25 items. To remove this limitation, please upgrade to the full version.”However, this message is incorrect because I already have a Pro/Lifetime license.Regular passwords usually still work, although the issue sometimes occurs there as well. With Passkeys, however, the problem happens almost all the time.WorkaroundThe only workaround that currently works is:Cancel the Passkey/password requestReturn to the iPhone/iPad home screenOpen Enpass manuallyAfter opening Enpass, it seems to switch back into Premium modeReopen the website or appNow the Passkeys/passwords are found and work correctly againUnfortunately, I cannot determine what exactly causes Enpass to suddenly switch into “Lite Mode.” The problem has been occurring repeatedly for months on multiple devices.Since the issue mainly affects Passkeys, using Enpass has become very unreliable.I would appreciate it if you could investigate this issue. If needed, I can also provide screenshots or additional information.Best regards,Clamsy Edited May 26May 26 by Clamsy
May 27May 27 Please ensure you have activated the Enpass app on all devices using the same Apple ID that was used to purchase the Enpass license.If the issue persists, please send a request to support@enpass.io so that we can investigate further.
