[Solved] How does TOTP work in Enpass?
Hello,
How can I use TOTP (2FA) within Enpass?
Is there somewhere a tutorial available?
Thank you!
Best regards
OLLI
Edited by OLLI_S
  • 2 weeks later...
Can anybody please explain me how TOTP (2FA) works in Enpass (the desktop app)?
How do I add 2FA codes?
Meantime I figured it out how this works.
But sad that nobody replied here (not even the Enpass team).
  • 2 weeks later...
Since you've figured out how to use TOTP in Enpass, would you mind sharing your solution? Enpass sometimes copies the 2FA code that I can then paste in, but at other times it doesn't. I'd like to avoid having to open my messages every time I need a code.
I did not know how to add the 2FA codes but found out that you have to scan the code with the mobile app.
And when you log into a website then Enpass fills the username and the password and copies the 2FA code into the clipboard.
But I assume you know this already (because it seems to work sometimes).
Maybe you have set the time until the clipboard is deleted to short?
Go to Settings -> Security -> Clipboard.
I have set here 15 seconds, maybe your setting is too short?
Does this help?
If you like my reply then please give me a "Like" (by clicking on the heart symbol)
Edited by OLLI_S
Even though you already figured out how 2FA works, I'd like to give another hint: you don't need mandatory a mobile app to scan the QR code, you can just insert the appropriate secret key (which is usually listed as an alternative to QR code) into a field that is configured to be a TOTP field and that's it.
Though I personally prefer to scan those QR codes as in the most cases they contain a lot of other informations like the website, your username, the time period for switching the codes or the number of digits used and the secret key code of course.
@xarekate thank you for this information, I did not know that the QR-Code contains these additional information.
