[Roadmap] Allow to login into Desktop Applications
Hello,
I really like Enpass, but one very important feature is missing: allow to login into Desktop Applications like:
  • Steam
  • uPlay
  • Game Launchers (like “Elite Dangerous” or “Star Citizen”)
  • Database tools
  • Admin tools
  • etc
Please add a way to log into applications by pressing the Assistant-Hotkey.
To identify the correct application you may use the process name or (like KeePass) the window title (but this is not really secure).
Here is the documentation about the Auto-Type feature KeePass:
https://keepass.info/help/base/autotype.html
KeePass protects the data while pasting using the Two-Channel Auto-Type Obfuscation:
https://keepass.info/help/v2/autotype_obfuscation.html
Best regards
OLLI
Edited by OLLI_S
Hey guys,
The suggested feature is already in our roadmap for the future version.
Thanks!
@Anshu kumar
Can you please tell us if this is planned for the next version or for a later version?
I am still using KeePass and this feature is the main reason why I did not switch to Enpass yet.
Thank you!
Edited by OLLI_S
@Anshu kumar
I am asking because I think about switching from KeePass to Enpass.
If this feature is coming soon, then it makes sense to switch.
If not, it makes sense to wait.
  • 1 month later...
Hello,
this stupid GeForce Experience application requests my password very often.
So logging into applications is really needed!
Best regards
OLLI
I´m upping this. Except for TOTP, i don't need to autofill web-forms nowadays since I like most others since the sessions are cached.
I do on the other hand have password protections on many applications, like a dozen Cryptomator-vaults. Autotype and being able to set a custom sequence for those records is mandatory for me, hence I use KeeWeb atm. But I'll switch right back to enpass once autotype is implemented cause it awesome otherwise
  • 1 year later...
Hey @Guillaume and All,
Thanks for showing your interest.
Significant user demand is a big factor that determines our priorities for new features. Due to frequently requested features like Website icons, include symbol feature and catching up with newly released OS/Devices, the priority of this went low. I'm really sorry to say that at the moment I can't assure you an ETA for the same.
Thanks.
Ok
thank you for your honesty ^_^
I hope this feature will go again at the top of the priority list ;)
  • 3 years later...
