webdav sync error 908413
I'm syncing with 3 devices without problems on the 4th device I get all passwords but at the next sync it hangs with the error 908413 "someting went wrong with the sync..."
- Bernhard
Edited by bernhard
Hi @bernhard
It would be a great help if you can share the demo account of your WebDAV via PM so that we can check where the problem could be.
Thanks for your co-operation.
