July 30, 20197 yr Hi, how can I delete a category that I've created? It seems that I cannot do it... I can only make them visible or not, but cant delete it..... it's really wired...
January 8, 20224 yr Hello people I have the same question, but the right click does not work for me. Where is that exactly? Greetings
January 9, 20224 yr Hey @Bleeddragon! Did you create the category by yourself that you want to delete? Because default categories are not able to delete. If you right-click a default category, nothing happens. You are only able to disable them in the settings menu. But if you right-click on a self created category, you are able to change the icon, rename and delete it. Hope this helps?
March 22, 20233 yr Go to customize settings of Enpass > Categories > Edit Categories > Unselect the categories which you want to hide from the sidebar.
