tobias Posted May 2, 2016 Report Share Posted May 2, 2016 (edited) I'm having issues with the extension in Chromium. The ctrl + \ keyboard shortcut works, but I don't get the popup when I click on the browser action icon. If I'm logged out of Enpass I have to go over to the app and log in that way. So, login is all I can do really, can't generate new passwords and it doesn't prompt me to save new logins. I'm pretty sure it worked on Chromium 50 earlier so the only change the last couple of days is that I updated Enpass to 5.2. Edited May 3, 2016 by tobias Link to comment Share on other sites More sharing options...
Hemant Kumar Posted May 3, 2016 Report Share Posted May 3, 2016 Hi @tobias If you're facing this issue in Arch Linux, please have a look a this topic Cheers! 1 Link to comment Share on other sites More sharing options...
tobias Posted May 3, 2016 Author Report Share Posted May 3, 2016 That did it! Thanks! Link to comment Share on other sites More sharing options...
