Posted
Enpass Autofill on Oreo causes lag in Pixel Launcher drawer
With the legacy Autofill Notifications enabled in Enpass, Pixel XL on 8.0.0 using Pixel Launcher has a laggy app drawer. Disabling the service and notifications removes this lag entirely.
Guest Akash Vyas
Posted
Hey @artemisbot
Thanks for writing in. I've forwarded this to the dev team to look into it. Till then I request you to please bear with us.
Cheers!
  • 2 weeks later...
Guest Vikram Dabas
Posted
Hi All,
Thanks for getting in touch. I am sorry that you are having troubles with the app. But this is a known issue where if any app uses the Accessibility service of Android system makes the device screen stutter. Enpass uses accessibility service for Autofill and that causes lagging on screen. As soon as there is a related fix by Google, we'll analyze that and revert.
The same is being discussed here https://code.google.com/p/android/issues/detail?id=81950.
