Posted
So does enpass have auto fill or not?
Best I can tell, auto fill either does not work or auto fill actually requires a couple of mouse clicks.
I dropped LastPass for enpass but from what I can tell the advertised auto fill does not exist.
Posted
It's not a real autofill like most browsers have them integrated it's more of a manual autofill.You would have to click twice to have the credentials fill the login fields.
  • 1 month later...
Posted
I've learned that Enpass offers two types of autofill login
  • By pressing the [Ctrl] [/] key combination
  • By clicking the Enpass toolbar icon
If a single corresponding accounts exist in the password vault, then the username and password will be automatically filled in.
If multiple accounts are in the vault, you can double click the selected account in a dropdown list.
I personally like the fact that Enpass does NOT automatically fillls the login form immediately the website is opened. Logging into a website with Enpass requires a deliberate action from me, which I regard as an extra layer of security. I'm also a user of LastPass and I find its fully automatied login too easy, particularly while it seldomly asks me for the main password.
I find the Ctrl-/ key combination very handy AND I very much like the automated [Enter] upon filling the username and password, which is not present with LastPass.
