Posted
I want to create a separate tracker for the problem described in other topic. Currently update check does not work on at least versions 5.5.6, 5.5.9 and 5.6 via EnpassMaintenanceTool with following error:
URL Scheme not supported: https (https://dl.sinew.in/linux/packages)
Guest Akash Vyas
Posted
Hey @Alex Gurenko
Please let me know the version of Linux OS you're using and the path of the Enpass installation directory.
Thanks for your co-operation.
Guest Akash Vyas
Posted
Hey @Alex Gurenko
One of our users had the same issue and he reported that he fixed the issue by installing "compat-openssl10-devel". So, for now, please try the same and let us know if it helps. We'll be looking for a fix on our end.
Cheers!
  • 1 month later...
Posted
On 12/5/2017 at 1:30 PM, Akash Vyas said:
Hey @Alex Gurenko
Cheers!
This package actually exists, but conflicts with openssl-devel package in Fedora.
