February 19, 20215 yr When I add a webdav server for sync, Enpass does not handle if I have special character in my path or space: Open-Xchange DAV: davs://foo.bar/servlet/webdav.infostore/Userstore/UsÉÉÉer%20NaÉÉÉme does not work but davs://foo.bar/servlet/webdav.infostore/Userstore/username does well (tested on Linux)
February 19, 20215 yr Hi @Peter Holtzl, Sorry for the inconvenience. Could you try adding %20 (for every special character) i.e if URL is "www.helloÉworld.com" use "www.hello%20Éworld.com". If the issue persists, let us know.
April 6, 20223 yr I can't believe this came from a team member. "%20" is the URL encoded representation of a space, not some weird escape sequence. The correct encondig of the URL above would be "davs://foo.bar/servlet/webdav.infostore/Userstore/Us%C3%89%C3%89%C3%89er%20Na%C3%89%C3%89%C3%89me" However, I found out that Enpass does neither require nor support pre-encoded URLs, not even "%20", which means you have to put "davs://foo.bar/servlet/webdav.infostore/Userstore/UsÉÉÉer NaÉÉÉme" to make it work. Edit: This worked for a while but is broken the latest releases. Currently there does not seem to be a way to get spaces or non-ascii characters to work at all. Support says they are working on it, but is has been three months already. Edited December 13, 20223 yr by Bachsau
