Posted
Hello,
I use Dropbox to store my Enpass vault. I would feel more comfortable if I can secure my Dropbox account with 2FA. However, will that break my syncing? I have searched the FAQ and this forum but I cannot find the answer. Thanks.
Posted (edited)
This will work as intended with 2FA and Enpass. Please do enable 2FA in Dropbox. Once your Dropbox is set up with 2FA, when you first enable Dropbox sync within Enpass, you will need to authenticate to Dropbox and it will ask you to confirm to allow the Enpass app access to your Dropbox. Once that is done you're good to go. If Enpass ever is unlinked you'll need to then repeat the sync setup process.
Edited by genbushi
Create an account
Register a new account
Sign in
Sign In Now
