DenalB Posted February 7 Report Share Posted February 7 I try to autofill login credentials on https://twitter.com/i/flow/login on Windows 11 Pro in Vivaldi browser 5.0.2497.48 (Stable channel) (64-Bit) with Enpass extension 6.7.4 installed. First, there is no inline popup. So I have to open the Enpass dock. When double-click on the entry with the matching credentials, a new website is opening in a new tab - https://twitter.com. I have to copy and paste the credentials manually. The same is happening in Microsoft Edge browser 98.0.1108.43 (Offizielles Build) (64-Bit) with Enpass extension 6.7.0 installed. Link to comment Share on other sites More sharing options...
Manish Chokwal Posted February 8 Report Share Posted February 8 Hello @DenalB, Thank you for reporting the presence of this issue. I have shared it all with the concerned team for further investigation. Your patience is highly appreciated here. Make sure you have enabled the option "Show Inline Autofill Menu" within the Enpass extension settings, and please help me with the Enpass app version (store or website). Link to comment Share on other sites More sharing options...
DenalB Posted February 8 Author Report Share Posted February 8 Hi @Manish Chokwal! 5 hours ago, Manish Chokwal said: Make sure you have enabled the option "Show Inline Autofill Menu" within the Enpass extension settings Yes. Setting is enabled. It works on other sites as expected. 5 hours ago, Manish Chokwal said: and please help me with the Enpass app version (store or website) Sorry, I forgot... I'm using the latest Website version 6.7.4 (933) of Enpass. 1 Link to comment Share on other sites More sharing options...
Create an account
Register a new accountSign in
Sign In Now
