We’re on Reddit now πŸŽ‰ πŸŽ‰ πŸ’¬ Come and join us there!! Γ—
Posted
Hello,
I have some websites with more than one login but I normally use only one of them - I'm the "family admin" and need to keep some of my family's passwords just in case.
So here's my question: Can I make one entry a default entry so when I open a website this entry is used for autofill and the others can be chosen in the dropdown menu?
Best Regards
Posted
Hi @0n10n
Welcome to the Enpass Community!
At the moment, it is not possible to make one entry as default. However, I have shared your comment as feedback with the development team so they may consider it for future Enpass versions.
Additionally, I would suggest keeping your personal and family passwords segregated. You can keep your passwords in your Primary vault and family passwords in a separate secondary vault. That way, you can use the vault selection menu in your Enpass app (on the top left side) to easily switch between your personal and family vault.
Create an account
Register a new account
Sign in
Sign In Now
