Posted
Hi
Looking for assistance/guidance on how I should set up my Enpass in a corp. environment.
At work we use Active Directory and all of our internal intranet sites authenticate against it.
Originally I had an Enpass entry for each site (containing the URL, Username, Password and MFA key). However, Enpass kept flagging the entries as "Identical Passwords".
I merged all the entries down into 1 site called "Work ADFS" and that has solved the identical password flag.
However, my new issue is that most of our sites also have MFA. I have merged all the MFA keys into the same Enpass/ADFS entry (see below)
My new issue is when I am navigating in the browser extension, only 1 MFA entry is available and the extension seems to use a hard coded "Copy OTP" label, so I am not sure what OTP I am copying.
Suggestion
1: Allow the browser extension to list multiple "Copy OTP" options
2: Use the label provided in the Enpass Entry so it is clear what I am copying. IE "Copy MoveIT OTP" instead of just "Copy OTP"
  • 2 months later...
Posted
On 12/6/2023 at 10:27 AM, its-nolan said:
Hi
Suggestion
Tengo los mismos problemas al agregar varios emails, lo que me obliga a separarlos y tener más plantillas para separarlos.
¿Pudiste encontrar una solución útil?
Posted
I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them.
 Thank you for your patience, and feel free to provide any additional feedback.
#SI-3673
  • Like 1
Posted
As suggested, create separate entries for each site in Enpass and input your username and password only once. Additionally, you can store one-time codes separately for each site to keep your information organized and easily accessible.
Create an account
Register a new account
Sign in
Sign In Now
