Posted
I can't connect to nextcloud using webdav or native nextcloud.
To debug I created a brand new nextcloud server with their docker container which works fine in browser. I input the URL in enpass like https://xxx/ and it tells me could not connect to nextcloud server even before asking me for a user. I have valid SSL cert but also disable SSl check makes no difference.
Also Web DAV is not working, within nextcloud I get my webdav URL like https://xxx/remote.php/dav/files/username but it tells me check user and passwort. I have a simple user without 2fa enabled and also tried to generate an app password which also does not work.
Nextcloud Hub 6 (27.1.5)
Posted
So I found the problem with wireshark, the TLS session failed. I had to remove the use modern cipher suites option from nginx and it worked.
No problem on every browser I used on differnent systems.
Create an account
Register a new account
Sign in
Sign In Now
