David321 Posted January 4 Report Posted January 4 I have to do a clean install of macOS. Doing so will erase all my data. I can't simply upload it to an external drive and then reload it after the clean install because, due to possible malware on my current system, I will have to reenter all my data manually. IS IT POSSIBLE TO DOWNLOAD MY ENPASS DATA INTO A PDF (or something similar) AND PRINT IT? Please help.
AnakinCaesar Posted January 6 Report Posted January 6 Export as CSV or similar and print it then. But that should not be needed, if you sync your Vault to a cloud drive.
Create an account
Register a new accountSign in
Sign In Now
