October 24, 20197 yr I just got a new Pixel and can't see most of my passwords. It still shows the correct number of passwords in each category, but I can't see them. I assume this is because I haven't upgraded to pro on this phone, but I can't find where to do it in the app. Help?
October 26, 20197 yr Same problem here If I unistall and reinstall on old phone it works. If I install it on new phone it shows just 20 items. But there's no way to upgrade
November 1, 20197 yr Hey @Beckanva and @Massimiliano, There would be an option "Upgrade to Pro" under Settings in Enpass. You can use it to buy Enpass or restore your purchase. Thanks.
November 1, 20197 yr I've got the same problem after upgrade to Android 10. I've bought some time ago Enpass Premium. It doesn't show "Upgrade to Pro" so I can't restore it.
November 2, 20197 yr Yep, just purchased pixel 4, synced my enpass data and can now only see 20 passwords. I'm sure I've already purchased this product originally. Any idea how to restore my purchase?
November 21, 20196 yr @Kashishhaving pro on Android as not registered user. As soon as I log in it reverts to lite limiting to 25 items. What's going on?
