August 11, 20179 yr Merge 2 cards Hi, Is there a way to merge 2 existing cards with data? For example, I have a fully filled card that I would like to merge with another one, containing extra data (like "Visa" card and separate "bank account" one). How could I achieve this? Thanks for your help
September 24, 20197 yr Hello! I am also interested in this feature. It would be great to have it in the next release Thanks for this great product.
February 6, 20206 yr Hi @Sander, Thanks for using Enpass and writing to us. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
May 4, 20206 yr Yeah, I regularly run into this situation. It would be very helpful to have the ability to 'merge' 2 cards.
May 4, 20206 yr Hey @Anthony We really appreciate you for exploring the app and giving time in this valuable suggestions. The suggestion has been noted and forwarded to the development team so that they can look at them. Thanks for your feedback!
May 9, 20206 yr I can't quite believe there's not more people expressing this wish. I've got loads of duplicate entries in my vault; from mobile and regular websites, from an app and a website... It would be *really* handy for me!
May 11, 20206 yr Hi @Martijn C, Welcome to the forums! We have noted down your feedback and forwarded it to the concerned team for further consideration. Thanks for your feedback!
February 16, 20215 yr It's been more than 3,5 years since the first request. Am I right in assuming that we never will have this feature?
February 18, 20215 yr Hi @Marinus, Sorry to say, but our team had a detailed discussion about this feature and came to a conclusion that currently we don't have plans to implement this feature. Thanks for your understanding!
June 14, 20215 yr What a pity, I would love to see this feature implemented, because I have the impression Enpass is creating too much entries for some sites/apps, or I don't use it properly... but I get many duplicates I'd love to be able to clean, in the way I would merge both cards into one to keep the information if there is a slight different.
May 1, 20224 yr Please reconsider adding this feature. If you can make it merge vaults, you can make it merge fields.
May 2, 20224 yr Hi @playmobilmeister, Our backend team is currently examining its feasibility. Additionally, I have also shared your comments with them as feedback. We appreciate your patience in the interim, and we thank you for your support. #SI-984
May 18, 20224 yr I usually create a new entry by hand and fill in all the data I need (login, pw, security questions, url and so on). Then I copy all the required values in the login fields on the website. However, Enpass will then ask me to save this in a new entry. This entry will then have the Webform and not my own created entry. I would like to merge the two entries. Unfortunately it seems that there is no way to add a webform to an existing entry (or is there?)
June 1, 20224 yr On 5/18/2022 at 1:21 PM, Stephane said: I usually create a new entry by hand and fill in all the data I need (login, pw, security questions, url and so on). Then I copy all the required values in the login fields on the website. However, Enpass will then ask me to save this in a new entry. This entry will then have the Webform and not my own created entry. I would like to merge the two entries. Unfortunately it seems that there is no way to add a webform to an existing entry (or is there?) if there is a way, I wasn't able to find it
