April 24, 20206 yr I've noticed even after upgrading to the latest Enpass program for both my iPhone and Windows 10 PC, the syncing no longer works with OneDrive. I've even disconnected the syncing on both devices and renamed the Enpass folder and file, and reconnected, but no syncing happens. On both devices, the Enpass app even says it "syncs" with OneDrive, but no Enpass folder and/or file is created in OneDrive.
April 27, 20206 yr Hi @JohnW, Sorry for the inconvenience caused to you Please share the following details so that we can investigate where the problem could be. On which devices and OS versions (mention all) are you using Enpass? Which Enpass version are you using on each device? Are you getting any error message or code during sync? If yes, share it with us. Does the Date and Time setting set to automatic on all devices? Does the last synced time get updated on the sync page? Thanks for your co-operation.
May 27, 20206 yr Running v. 6.4.4 (462) on my iPhone and 6.4.2 (668) on my Mac and now facing this error... No updates available for either. A tool is only a tool when it's not getting in your way to get things done... The MAIN reason I'm using Enpass is because of being able to use OneDrive, if this starts to not work reliably... :(
May 27, 20206 yr Hi @Fernando Madruga, Sorry for the inconvenience caused to you. Please let us know are you able to access all your data on any device? If Yes, follow the below steps to restore the sync: Take a manual backup of the data on all the devices. Disconnect the sync on all devices. Remove the Enpass folders from OneDrive account. Login to the site https://account.live.com/consent/Manage with the same Microsoft account and delete all the permissions for Enpass. Re-set up the sync with OneDrive on all the devices and check. If the issue persists, please let us know.
May 27, 20206 yr Hi @Pratyush Sharma. The above instructions seem to have fixed it: still a bit worried why I only found out about it when I tried using a password on one device that I had created on the other one even though I use Enpasss daily on both devices... Will see how it goes and if this happens again. Thanks, Fernando
May 28, 20206 yr Hi @Fernando Madruga, Thanks for your feedback. If you face any issues, revert to us.
June 4, 20206 yr On 5/27/2020 at 12:17 PM, Pratyush Sharma said: Hi @Fernando Madruga, Sorry for the inconvenience caused to you. Please let us know are you able to access all your data on any device? If Yes, follow the below steps to restore the sync: Take a manual backup of the data on all the devices. Disconnect the sync on all devices. Remove the Enpass folders from OneDrive account. Login to the site https://account.live.com/consent/Manage with the same Microsoft account and delete all the permissions for Enpass. Re-set up the sync with OneDrive on all the devices and check. If the issue persists, please let us know. Hi, I've got the same problem, but this does not solve anything unfortunately.
June 5, 20206 yr Hey @Alex Gerin Welcome to the forum! For testing purpose, we need a little input from you side so please take the backup of your Enpass data and perform these steps: Disconnect sync from all the devices. Download the debug version of Enpass from this link for macOS and link for Windows device. Now open Enpass --> Settings --> Advanced --> Logs --> Enable it. Now sync with One-drive. When you receive an error code --> Go to Advanced settings --> Logs --> Copy the Logs in any text editor and share with us on support@enpass.io. Thanks for your co-operation.
June 29, 20206 yr Author Hi @Pratyush Sharma Here are the versions of Enpass I have installed on 2 Windows PCs and 1 iPhone 7 plus. I followed your initial instructions, but the iPhone 7 Plus Enpass app refuses to sync data from/to the Windows Enpass programs. The 2 Windows 10 Enpass programs sync fine with each other. I deleted the Enpass file and folder from my OneDrive account, but it seems as if the iPhone Enpass application has it's own file/database that I can't find there and keeps on restoring data from. I don't get any error messages, other than the new records I enter don't sync from iPhone Enpass to Windows Enpass and vice-versa. I don't have automatic syncing set up. It's really strange. I used to see a folder and file for Enpass long ago when I first installed it, but now I can't find it? Is there a hidden folder/file? Also, how does one "disconnect sync"? iPhone 7 Plus (ver 13.5.1) ver 6.4.5 (467) Windows 10 Pro (ver 1909) ver 6.4.3 (666) Windows 10 Home (ver 2004) ver 6.4.3 (666) Thanks, John Edited June 29, 20206 yr by JohnW
June 30, 20206 yr Hey @JohnW Thanks for sharing the details- On 5/27/2020 at 3:47 PM, Pratyush Sharma said: Please let us know are you able to access all your data on any device? If Yes, follow the below steps to restore the sync: Take a manual backup of the data on all the devices. Disconnect the sync on all devices. Remove the Enpass folders from OneDrive account. Login to the site https://account.live.com/consent/Manage with the same Microsoft account and delete all the permissions for Enpass. Re-set up the sync with OneDrive on all the devices and check. We are investigating the issue and looking for a fix. Meanwhile please follow the above quoted steps and share your findings with us. Thanks for your co-operation.
July 3, 20206 yr Author Hi @Garima Singh, Thanks, I was able to resolve my problem by searching for the Enpass folder, which I found in the Apps folder. Previously, I had renamed an old Enpass folder to "Enpass 1", which may have caused the problem I was having. To fix, I downloaded the latest Enpass file as a backup, then deleted both Enpass folders and reconnected and resynced all 3 devices. John
July 6, 20206 yr Hi @JohnW, Thanks for notifying us. I'm glad to know that the problem has been resolved.
