May 13, 20206 yr Please bring back the Dark theme for Classic mode for windows. It works and looks awesome in Linux, why did you revoke it from the Windows app, it was there when version 6 was initially launched.
May 15, 20205 yr Hi @Ivarson, Sorry for the inconvenience caused to you. Dark mode in the classic theme is highly unusable and have issues that can't be fixed. We never provided dark mode support for the classic theme in the past but it can be enabled in some cases due to an existing bug (Enable dark mode in Modern and switch to Classic). I have noted down you request and forwarded it to the concerned team. Thanks!
January 8, 20224 yr Author Can this be reconscidered? I really fancied the Classic theme with dark mode. being on multiple desktop platforms it also feels nice to have the same UI
January 10, 20224 yr Hi @Ivarson and @DenalB, As already mentioned above we never provided dark mode support for the classic theme in the past but I have duly noted your feedback regarding this and it has been forwarded to the concerned team for further consideration. #SI-2389
January 10, 20224 yr Author 10 hours ago, Gulshan Dogra said: Hi @Ivarson and @DenalB, As already mentioned above we never provided dark mode support for the classic theme in the past but I have duly noted your feedback regarding this and it has been forwarded to the concerned team for further consideration. #SI-2389 I know. But still.. it worked without any noticeable glitch when I used it (before it was completely disabled). It would be one thing if only provided UWP /Modern theme for windows but since your shipping Enpass with classic and modern theme engine, I'd be thrilled if you could provide light /dark color schemes for both. Thanks
