May 25, 20206 yr Hi Enpass Team, the webform of my online banking is not saved correctly and autotype is starting in the 3rd of the 4 field. I have tried to create new entries and to save the form manually. All withe the same result. Could you have a look at it? Thanks in advance. https://meine.norisbank.de/trxm/noris/ Kind regards Mathias
May 25, 20206 yr Hi @datarepos, Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass version are you using?
May 26, 20206 yr I have the same problem https://meine.deutsche-bank.de/trxm/db/ Save Webform has no function in Safari. Save dialog does not pop up. No entry in the database for that website. MacOS 10.15.4 Enpass 6.4.2 Plugin 6.4.2 Edited May 26, 20206 yr by xterm
May 26, 20206 yr Hi @xterm, Welcome to the forums! I have noted down this issue and notified the QA team to look into it.
May 27, 20206 yr Author Hi, I am using enpass 6.4.2 with browser extension 6.4.0 on macOS 10.15.4 Regards Mathias
May 28, 20206 yr Hi @datarepos Thanks for sharing the details. Our Dev team is working on it. Hopefully, fix will be available in the future updates. Till then, we will request you to please co-operate with us. Thanks!
May 29, 20206 yr I also tested on: WIndows 10 FirefoxEnpass 6.4.2Plugin 6.4.2 Same problem. - Save webform has no function. - Enpass is not asking for saving credentials. - Manual setup of a login not working. Edited June 2, 20206 yr by xterm
June 13, 20206 yr On 5/26/2020 at 10:02 AM, xterm said: I have the same problem https://meine.deutsche-bank.de/trxm/db/ Save Webform has no function in Safari. Save dialog does not pop up. No entry in the database for that website. MacOS 10.15.4 Enpass 6.4.2 Plugin 6.4.2 I have the same problem with Deutsche Bank. Still not solved. It seems that the "auto fill" in "web forms" does not work.
June 15, 20206 yr Hey @eddi and @xterm @datarepos Thanks for sharing the details. I would like to share that the issue has been reproduced by the team. Our team is now working to fix the issue. Your co-operation will be highly appreciated. Thanks for understanding.
October 26, 20206 yr Hi @xterm, We regret the problem you are facing. Our team has fixed similar issues in the upcoming v6.5.1 release of Enpass Extension. Stay tuned for the new version to be released and then share your findings with us. Thanks for the co-operation.
March 10, 20215 yr Author Hi Enpass Team, any updates from your side. The autofill for my banking website is still not working, it is now march 2021, and the Extension 6.6.0 in use. Thanks and regards Mathias
March 10, 20215 yr Hey @datarepos We regret the inconvenience. The issue has been reproduced with the latest version of Enpass extension and we shared it with the team to fix it. Thanks!
March 10, 20215 yr Author This is the same answer as last year and the problem still exists. This kind of support is not very helpful for your paying customers.
March 12, 20215 yr Hey @datarepos Apologies for the trouble that you have been facing with this. We understand how frustrating this could be. The issue is fixed on other browsers i.e Chrome, Firefox except safari. While we are working to fix the issue with safari browser as well, please check the issue with Chrome browser and share your feedback. Thanks!
