May 26, 20206 yr Hello, please help in 2 regards: 1) When I ask support for help with syncing problems, they always ask to „provide the WebDAV-demo account”. But the utility I use (WebDAVNav Server from 'Schimera Pty Ltd', see Pic) does not need an account anywhere, it's all on my Mac. Please clarify, what I should provide. 2) Which WebDAV software can you recommend for reliable syncing? Is the one I use (WebDAVNav Server from 'Schimera Pty Ltd') the best choice? I do not want to use any cloud, it should all be locally on my iMac (of 2019, Mojave). Thank you for recommendations. Robert
May 27, 20206 yr Hi @Roobert, Welcome to the forums. Please share your Enpass support ticket id so we can help you better. Thanks!
May 27, 20206 yr Author At the moment I don't have an open support ticket, that's why I have asked the 2 questions in general (please see my 1st post in this thread). Thanks in return. ;-)
May 28, 20206 yr Hi @Roobert, Thanks for writing back in. You can choose any compatible account as Enpass supports variety of cloud providers for sync via WebDAV. Please refer the help category for list of supported cloud accounts via WebDAV. If you have any difficulty, please let us know.
May 28, 20206 yr Author Dear Pratyush, currently, my only problem is that I cannot make myself understood. ;-) I do not use any cloud service for WebDAV-syncing, it's all on my Mac. That given, please do read my opening post with the 2 questions again. Thanks.
May 29, 20206 yr Hi @Roobert, Thanks for writing back in. You won't be able to sync with a local WebDAV server in Enpass until the server is accessible over the internet and has a username and a password to which Enpass could connect to. If the WebDAV is available for connection on the internet with a username - try the same in Enpass.
May 29, 20206 yr Author ? Please take a look at the screenshot in my 1st posting. It shows an URL with a LOCAL IP https://192.168 ... I have benn syncing my several devices with my iMac without Internet for about 2 years.
June 1, 20206 yr @Roobert On 5/29/2020 at 8:04 PM, Roobert said: It shows an URL with a LOCAL IP https://192.168 Okay. We see that, but do you want to sync Enpass database over the same WebDAV? In the context of our application, WebDAV sync implies syncing your vault over a WebDAV account so that you have access to your passwords across all devices. Is that what you're looking for or is it something we've misunderstood? In Enpass, under WebDAV vault sync, you can try entering the same URL 192.168.xxx.xxx in the URL field, but again, that would require a username and a password. Why don't you try the Folder sync option available in the vault sync settings. It seems that the WebDAV on your MAC could be accessible as a network folder. Let us know. Thanks.
