July 1, 20206 yr Hello, after switching to a new phone running Android 10 (old phone was running Android 9) autofill doesn't work for me anymore in apps that worked before (on Android 9). Autofill is enabled in Enpass ("Android Autofill Service" enabled, "Enpass Keyboard" enabled, Autofill using Android Accessibility is enabled). When I open the app and get the login prompt I can see the Enpass icon appear in the status bar, but nothing happens. When I press the user or password field , select the 3 dots and select AutoFill I get the message "Content can't be filled automatically (translated from German message "Inhalte können nicht automatisch ausgefüllt werden"). Is this a problem of Android 10, Enpass (version is 6.4.5.368), the app (for example Flagstack app, Geocaching Adventure Lab app or komoot app) or me?
July 2, 20206 yr Hey @Oceanwaves Sorry for the trouble you are having. Thanks for reporting this issue. I have shared your inputs to the team. Hopefully, an update for Enpass will be released soon in which we've significantly improved auto-fill feature. Please stay tuned for the new update and let us know if the problem still persists after the updated version. Thanks.
September 9, 20206 yr Hey @Oceanwaves We've released an updated version of Enpass(v6.5.1) for Android device in which we have fixed this issue. Could you please update the app to the latest version and let us know if you're still encountering the same issue with the app? Thanks for the co-operation.
September 24, 20206 yr Hi team, for me autofill don't work in some apps and websites. It fill username but not passwords sometimes. For this cases, I miss the feature for copy user or password directly from enpass box. I have enpass premium installed in a Android 10 phone (Pocophone F1, MIUI 12.0.1)
September 24, 20206 yr Hey @ATurkey Welcome to the forum! Sorry for the inconvenience. Please share the following details so that we can investigate where the problem could be. Which Enpass version are you using on the same device? Let us know the websites or apps in which you are facing this issue? Which browser you use on the same device? Are you facing the same response with other browsers too? What method you use to auto-fill the details(Keyboard, framework or accessibility)? Thanks!
September 28, 20206 yr Author On 9/9/2020 at 7:28 AM, Garima Singh said: Hey @Oceanwaves We've released an updated version of Enpass(v6.5.1) for Android device in which we have fixed this issue. Could you please update the app to the latest version and let us know if you're still encountering the same issue with the app? Hello and sorry for the late reply. I'm currently running Enpass 6.5.2.404 on my OnePlus 7T (OxygenOS 10.0.12) and the problem still exists. Which Enpass version are you using on the same device? -> 6.5.2.404 Let us know the websites or apps in which you are facing this issue? -> App not working: Flagstack (https://play.google.com/store/apps/details?id=net.flagstack.app). Autofill worked fine on my OnePlus 3T running Android 9. Which browser you use on the same device? -> Chrome Are you facing the same response with other browsers too? -> No problem in browsers What method you use to auto-fill the details(Keyboard, framework or accessibility)? -> "Android Autofill Service", "Enpass Keyboard" and "Accessibility" are all enabled Edited September 28, 20206 yr by Oceanwaves
October 1, 20206 yr Hi @Oceanwaves, Thanks for sharing the details. I have noted down your feedback and we are looking into it.
December 26, 20205 yr When I make an html anrdoid app I use <form autocomplete="on" and submitting input fields with the attribute name="name, sjekk, tel ... and the phone cant get the autofill, but my computer can, does your program fiks this ishue? or do I have to change my program?
December 28, 20205 yr Hey @svein Øivind Dahlseng Welcome to the forum! Our team has fixed this issue in the v6.6.0 release of Enpass which is currently in the beta phase. Please wait for the stable version to be released and then share your findings with us. Thanks!
January 13, 20215 yr Hi, I'm using duckduckgo browser on Android. Enpass doesn't work very well. Frequently it won't autofill. Any way to overcome this? Cheers.
January 13, 20215 yr Hey @DomB Welcome to the forum! For Android, Enpass autofill is supported on Chrome, Edge, Firefox Focus, and Opera browsers. The request to support Duckduckgo browser has been already noted and shared with the team. Thanks!
January 15, 20215 yr Author I'm now on Enpass 6.6.1.449 and don't see any improvements in Autofill. Strange thing is that for the mentioned Flagstack app Autofill doesn't work when app asks for user/password, but works after successfully logging in: on the login screen the Enpass icon appears on the status line. When I drag it down there is a notification from Enpass saying "Touch for Autofill" (translated from German). When I touch it it returns to the app but nothing happens. After logging on the Enpass icon is still on the status line. When I now touch the notification Enpass is started, I unlock it, and Enpass offers to transfer username and password to the app. But this happens only after I logged in to the app manually. Another app that doesn't work with Autofill here is Polarsteps app. BTW: After switching options in Autofill settings off and on again the Enpass icon now doesn't appear anymore when trying to login in above mentioned apps. So strange... Edited January 15, 20215 yr by Oceanwaves
January 15, 20215 yr Hey @Oceanwaves Thanks for sharing your feedback on this updated version of Enpass. Your input has been shared with the team so that they can more thoroughly analyze the issue again. Thanks for the co-operation.
March 7, 20233 yr I have been using the DuckDuckGo browser on Android since it was available. Support helped me to work through the problems. The best solution is to enable the Enpass keyboard (settings) and then switch to that keyboard when you need to AutoFill. It works very well and with only a slight inconvenience.
