November 10, 20206 yr If have enabled Touch ID on my MacBook Pro (2016) with macOS 11.00.01. If I restart my Macbook I can enable Enpass with Touch ID. That's good but everytime it is locked I have to use the Master-PW. That is not ok. Anybody knows a solution?
November 12, 20206 yr Hi @Tranel, We are sorry for the inconvenience caused to you. We have taken note of this, and our team is now analyzing into the issue. Meanwhile, please let us know which Enpass version are you using so we can further investigate.
November 13, 20206 yr Author Thanks for your response. I am using the latest version from the Apple App Store: 6.5.2 (726). MacOS is the 11.0.1 (20B28).
November 17, 20206 yr Hey @Tranel Thanks for writing back. I have checked and the same is working fine in our testing environment. Please share a video of the issue so that we can try to diagnose the issue again.
November 20, 20206 yr Author Hi I cannot make a video but I have some pictures. After a restart of my Macbook Enpass opens up and I can unlock it with Touch ID. Every time I sent my Macbook to sleep and I open up it again, Enpass is asking for the master password. There is no option to use Touch ID. As you can see on the picture. Guido
November 23, 20206 yr Hi @Tranel, Thanks for sharing the details. We've been able to reproduce the issue on our system and now working towards a fix. Please co-operate with us!
December 22, 20205 yr I have the same issue on Big Sur using the latest MacOS Version of Enpass. Any fix yet?
January 2, 20215 yr Is there an update on this? I am having the same issues on Big Sur 11.1 and it is pretty annoying.
January 4, 20215 yr I am also experiencing the same problem. The problem occurred immediately upon updating with Big Sur. With Catalina it worked well.
January 5, 20215 yr Hi @OP38 @wuedan @Gaetano, Sorry for the trouble you are going through. Our team is working on it. Hopefully, fix will be available in the future updates. Till then, we will request you to please co-operate with us. Thanks!
January 7, 20215 yr Dears, I face the same issue. Master-PW is requested if MacBook was on sleep or switch user. If I enable PIN instead of Touch ID it works as expected (always the PIN is requested). I use MBP 16 inch 2019, BigSur 11.1, Enpass 6.5.2 (726)
January 11, 20215 yr Same issue here. My master password is a long, complicated one, and now that I have upgraded the OS to Big Sur, I have to enter it 10 to 15 times a day. This is a real usability problem.
January 12, 20215 yr Hey @ben1265 I apologize for the trouble you are facing. The Touch ID issue on macOS Big Sur has been fixed, and an update with the fix will be rolled out soon. I appreciate your patience and cooperation.
January 23, 20215 yr Software bugs or incorrect settings may cause this problem. Just like my iPhone Touch ID did not work before. Edited January 28, 20215 yr by amarjitsingh
January 25, 20215 yr Author On 1/12/2021 at 2:04 PM, Garima Singh said: Hey @ben1265 I apologize for the trouble you are facing. The Touch ID issue on macOS Big Sur has been fixed, and an update with the fix will be rolled out soon. I appreciate your patience and cooperation. Any news? Still waiting.
January 27, 20215 yr Hey @Tranel We have released the beta version of Enpass v6.6.0 with the fixes. Please wait for the stable version to be released and then share your findings with us. We'd love to have your feedback. Thanks!
February 6, 20215 yr Thanks this is a very good help. When it is fixed Edited February 6, 20215 yr by Scrabber
February 8, 20215 yr Hi All, Thanks for the patience. Our team has fixed similar issues in the v6.6 of Enpass. Please update the app and let us know if the issue still persists.
February 8, 20215 yr I was testing this fix and something very strange/scary just happened: I upgraded, reopened Enpass (it asked me for the password) and made sure everything looked OK. I then put the the laptop to sleep and woke it up after an hour or so. When I logged back in, I was able to reopen Enpass, but my vault appeared completely empty. NOTHING WAS THERE! Restarting the app fixed the issue, my entries show up again. But of course, that defeats the fix, as I had to enter the master password after restarting the app.
February 8, 20215 yr I just reproduced the problem. There seems to be a serious bug there. If my Mac goes to sleep for an hour or more, when I try to access Enpass, I can unlock using my fingerprint, bu the vault appears completely empty. See attached screen shot. Quitting Enpass and restarting it fixes the issue.
February 15, 20215 yr I have exactly the same issue. It shows as if I have elements in my vault, yet they are not there. When I close and reopen, they reappear. Very annoying. Edited March 13, 20215 yr by roklipni Typo
February 17, 20215 yr On 2/8/2021 at 3:08 AM, Pratyush Sharma said: Hi All, Thanks for the patience. Our team has fixed similar issues in the v6.6 of Enpass. Please update the app and let us know if the issue still persists. Hello, Enpass team. Were you able to reproduce this "vault appears empty after a fingerprint unlock" problem? I have to deal with this several times a day (and a couple of crashes as well); it's super easy for me to reproduce if you need help with that. Thanks.
February 17, 20215 yr Hi team, I am having the same issue for a while now, any idea when it will be fixed? Thanks
February 18, 20215 yr Hi @ben1265 @roklipni @mmaurice, Thanks for reporting this issue. We've been able to reproduce the issue on our system and now our team is working on it towards a fix.
