December 18, 20205 yr I have a website where I have to use a password which consists of 4 numbers and the 2fa code. Actually I'm using the shortcut to fill in the password and pressing "ctrl+v" to copy the 2fa code directly behind the password. Is it possible to automatically fill in the 2fa code directly behind the password? I couldn't find a setting for this behavior.
December 24, 20205 yr Hi @DenalB, Thanks for using Enpass and writing to us. We have taken note of this, and our team is now analyzing the issue. Meanwhile, please let us know on which website you are facing this issue to help you better.
December 25, 20205 yr Author Hi @Pratyush Sharma, It's not an issue. It's a feature on one specific website - https://login.mailbox.org/de. For security reasons you have the possibility to enable 2FA protection. That means you have to use a password which consists of 4 digits. If enabled you have to type in the TOTP code right behind the 4-digits-password. So you have a password which consists of 10 digits. It would be awesome if Enpass has a script to put both together in the same field - 4-digits-password and TOTP.
December 28, 20205 yr Hey @DenalB Thanks for writing back. Enpass already has the feature of TOTP which you can set for any website in Enpass. To know more, please have a look at this link to our user manual. Let me know if this doesn't help.
December 28, 20205 yr Author Hi @Garima Singh, That's not the problem. I'm already using TOTP for some websites. But thanks for the link.
December 29, 20205 yr Hey @DenalB We have noted your suggestion of the feature for this specific website. Thanks!
September 15, 20215 yr I would like to second this feature request. It is not uncommon for corporate Single Sign on applications to require username and password + TOTP. Given the following values: Username: rallour Password: mypass TOTP: 323813 The login form would then be filled in with the following: Username: rallour Password: mypass323813 The way I would like to see it solved is to be able to use a template for the password field. This would allow me to combine two arbitrary fields (a static password, and a dynamic TOTP) to create a password field that is a combination of both the password and TOTP as the value, and then have that templated value be what is auto-filled into the form. RIght now it works with multiple selection and copy/paste steps, but it'd just a nice quality of life feature as I end up needing to do this multiple times per day supporting different customers, all of which require the format of username / password + TOTP. Thanks for a great product, and especially thanks for supporting it on Linux! Jason Edited September 15, 20215 yr by Jason Smith
September 16, 20215 yr Hello @Jason Smith! Welcome to the Enpass Forum. Thank you for your kind words, Enpass would not be where we are today without the support of our wonderful customers. Enpass already supports this feature for a few hard-coded websites Url only. Could you help me with the website Url on which you wanted this feature?
December 10, 20214 yr Author On 9/16/2021 at 7:49 AM, Manish Chokwal said: Enpass already supports this feature for a few hard-coded websites Url only. Could you help me with the website Url on which you wanted this feature? This is the website where I need this feature, and it would be awesome, if you could hard-code this in here too. https://login.mailbox.org/de And for the English-speaking folks, this is the link: https://login.mailbox.org/en Thanks in advance!
