my own categories + longer passwords
Hi there.
I want to create my own categories,  I personally feel restricted with this thema,  I used to have keepass and with it I was able to do it.
I have almost 50 logins and I don't want to spend time typing in the search bar for it.
Also the password manager is super n better than the one found in 1 password the only problem for me just the PASSWORD LENGTH.... Just to short because I do have also passwords of the company where I work ant they are much longer.
Thanks
Hello @alien51O.o
You can still organize your various passwords using Folders. Folders in Enpass works like traditional system where you can create subfolders to keep your data in desired hierarchy. Even you can control the visibility of Folders in sidebar.  If there is something else, you want to achieve please leave your comments and we will definitely give that a serious thought.
@Hemant Kumar
is there a way to remove things (Favorites,Login, Credit card and so on) from the current siderbar? I would like to keep only my folders there.
I don't see that Sidebar customisation on the desktop client (Windows).
Screenshot attached.
  • 1 month later...
I would love to be able to add my own categories. One thing I would also like to be available was tags. It makes everything easier to find and organize. But this password manager is great.
Thanks
