September 27, 20215 yr I had this pop up on Dropbox, any ideas? "It seems that the password of data on dropbox has been changed lately please enter the new password to continue sync"
September 28, 20215 yr Hi @aaronbernak You might have recently changed Master Password on your Device A which has encrypted your backup files with the updated Master Password hence if you are trying to sync your items on a Device B, it is asking for your new Master Password (although you can login on Device B with your old Master Password). Please enter the latest Master Password in the prompt and it will resolve the sync issue. Let me know if it works for you.
November 5, 20215 yr Hi @Abhishek Dewan and @Manish Chokwal, this is IMHO another instance of the same error reported in this thread. Would be great to see this fixed, as it re-occurs every few days even after completely resetting sync. Thank you!
January 8, 20224 yr I am having this same problem, but I have not changed any passwords either on Enpass devices, or on Dropbox. Any other ideas?
