Restore from Google Drive stuck
Hi all,
after having uninstalled and re-installed in windows 10, I want to restore the data from google drive, but i get stuck here, indefinitely, without any of my browsers opening the login page. my internet connection is fine.
Enpass version 6.74.934.0
Edition    Windows 10 Home
Version    21H1
Installed on    ‎12/‎10/‎20
OS build    19043.1415
Experience    Windows Feature Experience Pack 120.2212.3920.0\
Edited by playmobilmeister
added info about interent connection
Hey,
Try changing your default browser to chrome/firefox incase you are running any other.
Hope this helps!
Hello @playmobilmeister,
Make sure the date & time must be the same on all the devices. Also, please disconnect the Google Drive sync from all the devices, and sync them again. Let me know if that helps.
  • 2 weeks later...
It didn't help me. I re-installed (again), then restarted again the computer and it worked for some reason this time. thanks
