Can Enpass autofill custom forms?
I have a bank website with different type of data for input , not the usual username+password fields. is there a way to teach Enpass to autofill it?
1password could  not do it but I messed around with the login template in a way that it finally was able to do so , but the same messing around did not work with Enpass for me (imported)
isn't there a way to autofill a form then "save" it as is then Enpass can just refill it each time?
Edited by flyingbirds
I don't think that custom forms could be filled. I tried and it didn't work for me. :/
But it would be great if there could be a possibility for that. :)
Edited by DenalB
Typo
So Enpass is limited to filling usernames and passwords only?
You can store an email address which would be filled.
Also identities and credit cards would be filled.
Hi @flyingbirds
I would like to clarify that yes, you can autofill multiple fields on a webpage by first saving the details in Enpass as a webform. Please refer to this link for instructions on how to create an Item as a web form.
35 minutes ago, Abhishek Dewan said:
Hi @flyingbirds
thank you
the website I am refering to is this: https://qpay.credimax.com.bh/
There seems no "Save as webform" option for me.
Hi @flyingbirds
To get this thoroughly investigated, please share the below details with me, and I'll get it checked for you -
  1. The version of the Enpass app, OS, Extension and browser you are using.
  2. Are you facing a similar concern on any other websites as well?
On 2/8/2022 at 3:06 PM, Abhishek Dewan said:
Hi @flyingbirds
MacOS Mojave
Enpass 6.7.4
Firefox 96.0.3
I have ublock origin, night reader, I do not care about cookies, FF multi container, and Enhanced tracking protection set to STRICT
Same issue on brave and safari for that specific site I mentioned.
I tried Nike and Amazon and I did get the "save as webform" option.
Hi @flyingbirds
After thoroughly investigating the web page you mentioned (https://qpay.credimax.com.bh/), it appears that this webpage does not have a password type field. Thus, Enpass is unable to display the 'Save as Webform' option in the Extension menu and auto-fill on this website.
Our team has taken note of this behavior, and we are currently working on a workaround to address this issue. We appreciate your patience during this time.
#SI-2617
