April 23, 20224 yr Hi, is it possible to include my tags in the search? I have all my projects tagged with a project name but if i enter this tag in the search nothing happens. Edited April 23, 20224 yr by axelf
April 25, 20224 yr Hi @axelf, Thanks for reaching out to us. You can quickly access all the tags saved in Enpass from the sidebar. Just select Tags from the sidebar, and you’ll be presented with the list of all the existing tags in Enpass. To know more about tags and sub-tags refer to this link from our user guide.
April 25, 20224 yr Author Hi @Gulshan Dogra i know, but i want to type a tag in the searchbar and see all entries having this tag. This is much quicker. Is this possible?
April 25, 20224 yr @axelf, Currently its not possible to search tag in the search bar. Although, I have taken note on this and forwarded your suggestion to the concerned team for further consideration.
August 20, 20224 yr I'm also very much in favor of being able to search by tags. From me via #tagname. But using the search bar to search a tag from over 200 tags is unacceptable. That's not quick access
August 22, 20224 yr Hi @_BJ, Welcome to the Enpass community. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback! #SI-2548
November 2, 20233 yr +1 here. I just migrated from 1password and this feature will be very useful for users like me with over 200 tags and 2k entries.
August 17, 20242 yr Author Still nothing happend. Is it so complicated to implement this feature? I think this is a really easy task.
July 16, 20251 yr On 8/22/2022 at 10:53 AM, Gulshan Dogra said: Hi @_BJ, Welcome to the Enpass community. We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback! #SI-2548 Has anything changed regarding searching by tag in the past three years? Was the suggestion rejected all those years ago? Any update on this would be appreciated. Cheers, have a good one
July 18, 20251 yr We've shared your feature request with our technical team. It's pending for a future roadmap. We appreciate your patience and understanding.
August 14, 20251 yr Thank you for sharing your thoughts with us. We've passed the request to our technical team and are monitoring its progress. We’ll make sure to keep you updated.
