May 26, 20224 yr I changed my password on my OneDrive account - which is used for Sync in Enpass. Now Enpass just sits there trying to Sync. I can't stop it and therefore I can't enter new account details. Without new account details it won't work. Please tell me how I stop the Sync'ing.
May 26, 20224 yr Author Just to add a little more. It's dead easy to do this on iPad and iPhone. You can choose disconnect and then just reconnect. You can do this whilst the sync is in progress. On the PC however there seems to be no obvious was to do this. And I haven't tried the Mac yet.
May 26, 20224 yr Author I think I've worked this out. Pure trial and error. If I type in my password. Hit enter. Then very quickly press the onedrive icon, I have around 0.5 seconds to hit disconnect FAST. I failed a few times, but finally managed to do it. Seems now I can disconnect and reconnect. Then to try the Mac :-(
May 26, 20224 yr Author Process was the same on the MAC. A vital tip though. On PC and MAC you need to close Enpass from the System tray too. This gives you the vital part of a second you need to reach the disconnect button. Otherwise it syncs instantly. In future. ALWAYS disconnect SYNC before changing your password for the service used in Enpass. Even better.... It would be great if Enpass could add a function to either STOP SYNC or an option to NOT SYNC AUTOMATICALLY ON STARTUP. However I saw the later was requested by users 4 years ago and was never implemented. Once again. There are no issues on iPad or iPhone where you can easily disconnect, even whilst sync is in progress. Good luck.
June 1, 20224 yr Hi @Andy_1, Welcome to the Enpass Community Forum. I appreciate your feedback and your request to include either a "Stop sync" or an option to "Not sync automatically on startup" has been shared with the concerned team for further consideration. In the meantime, your patience is highly appreciated here. SI-2895
October 8, 20224 yr To check your network type on the server, go to Device Settings > Network and Internet > Status > Properties > Network profile. It would be either “Public” or “Private”. If Windows had already displayed the Firewall popup and you don’t know which option you selected, follow these instructions to reset the access permission for Enpass Wi-Fi Sync Server. Open Windows Device Settings > Control Panel > System and Security > Windows Defender Firewall > Allowed apps. Navigate to wifisyncserver_bin. Select wifisyncserver_bin and click Remove. Now open Enpass and go to app settings > Wi-Fi Sync > Stop Server. Restart Enpass and go to app settings > Wi-Fi Sync > Start Server. When the Windows Defender Firewall popup is displayed, click the corresponding Private or Public checkbox and ‘Allow Access’. Regards, James
September 26, 20251 yr Please follow the steps below to stop Wi-Fi sync: Turn off your internet connection (or enable flight mode) on your device. Close the Enpass app completely and remove it from recent apps. Reopen Enpass. Navigate to the vault that appears to be stuck. Tap Disconnect to remove the Wi-Fi Sync setup.
