August 28, 20224 yr Hi team I am using the latest version of Enpass on Mac and iOS devices, installed via the App Store. Enpass gets very slow, freezes, often crashes to an extend that the app is not usable anymore. I have 800+ password entries in 1 vault. My sync service is a local WebDav service. Any help is very much appreciated.
August 29, 20224 yr Hi @Bob2 Welcome to the Enpass Forums. Please share the below details with me, and I'll have this further investigated for you - The version of the Enpass app and OS you are using on your iPhone and Mac. The number of Items and vaults you have saved in your Enpass app on both devices. Is there any particular step after which the lag occurs (updating an Item, adding a new Item etc) on your devices? Is the Enpass app showing you a crash report after the crash? If yes, kindly share it with me.
August 30, 20224 yr Author Enpass on Mac 12.5.1: 6.8.2 (Opening a vault uses 6GB of memory and freezes for 30 seconds) Enpass on iOS 15.6.1: 6.8.1 800+ items are stored
August 31, 20224 yr Hi @Bob2 Thank you for sharing the details. I have forwarded this concern to our dedicated testing team and will get back to you soon with an update. Your patience in the meantime is appreciated. #SI-3072
September 1, 20224 yr Hi @Bob2 We are investigating the issue which you reported. Our dedicated team is looking into it but requires some additional information in this case. Could you please check and share the size of the vault.enpassdb file? The complete path is library/Container/Enpass/Data/Documents/Primary/vault.enpassdb. Your cooperation in this case is appreciated.
September 2, 20224 yr Hi @Bob2 Thank you for sharing the information. I have forwarded it to our dedicated team and will be sure to let you know of any updates regarding this concern.
September 6, 20224 yr Hi @Bob2 To replicate the exact scenario due to which you are facing this issue, could you please share the attachment size you are using in total? Under the file location: library/Container/Enpass/Data/Documents/Vaults/Primary/vault.enpassdb, please share - 'enpassdb' file size Total file size of all the .enpassattach file (Please refer to the below screenshot)
September 6, 20224 yr I also started having this issue. First on my android, where i noticed it was not as bad if i diabled my wifi, thinking it had something to do with sync. yesterday my laptop (debian linux) started going really slow as well. i saw this thread about the db size and I looked: on Sept 5, my db went from 13M to 245M -rw-r--r-- 1 dab dab 13M Aug 25 08:52 2022-08-25-1661431923-1_vault-1460_items-auto.enpassbackup -rw-r--r-- 1 dab dab 13M Aug 26 16:04 2022-08-26-1661544254-1_vault-1460_items-auto.enpassbackup -rw-r--r-- 1 dab dab 13M Aug 28 16:29 2022-08-28-1661718568-1_vault-1455_items-auto.enpassbackup -rw-r--r-- 1 dab dab 13M Aug 30 09:41 2022-08-30-1661866906-1_vault-1455_items-auto.enpassbackup -rw-r--r-- 1 dab dab 13M Aug 31 19:38 2022-08-31-1661989102-1_vault-1455_items-auto.enpassbackup -rw-r--r-- 1 dab dab 13M Sep 2 09:48 2022-09-02-1662126497-1_vault-1455_items-auto.enpassbackup -rw-r--r-- 1 dab dab 245M Sep 5 23:04 2022-09-05-1662433424-1_vault-1454_items-auto.enpassbackup -rw-r--r-- 1 dab dab 245M Sep 6 10:10 2022-09-06-1662473384-1_vault-1451_items-auto.enpassbackup I tried to create a backup, as it was the only option i could find, but it created the same size. i tried looking for large objects, but the app has become too slow to navigate at all. is there any way i can export everything and reimport? this is really going to block me from getting any work done at all until it's fixed. Edited September 6, 20224 yr by dab
September 6, 20224 yr I'm also having this problem for over 1 month and I've seen other user complaints related to it. Any predictions for resolving this bug? Remembering that I currently use Linux Ubuntu Link to another story:
September 7, 20224 yr Add another user to the list that is having this problem, roughly for a month now, under Android and Linux. Enpass is now unusable. I resorted to exporting the database as text and entering passwords manually Local vault files: └─ [07.09.22 10:39:13] $ ls -alh total 556M drwxrwxr-x 2 4.0K Sep 7 10:36 . drwxrwxr-x 3 4.0K Sep 10 2021 .. -rw-rw-r-- 1 87K Sep 10 2021 19aec948-de48-410f-a866-dc46644415ea.enpassattach -rw-rw-r-- 1 556M Sep 7 10:36 vault.enpassdb -rw-rw-r-- 1 496 Sep 7 10:36 vault.json I also notice that my Backups have exploded in size: On 10th of August backups went from 7MiB to 51 MiB On 5th of September backups went from 51MiB to 513MiB I will check my other machines later to see if I notice the same exploding size backups I normally sync via a private WebDav file store, and tried switching to file sync instead, but nothing seems to help. I have 648 entries in a single vault. When unlocking the vault, Enpass will freeze for about a minute, pegging one core at 100% When searching for an entry in the vault, Enpass will take anywhere between 5s and 30s to filter the list Clicking on the Enpass icon in the browser takes about a minute to show the pop down asking for a password, if the vault is still locked EDIT: Version used under Linux -> 6.8.1 (1063) Edited September 7, 20224 yr by fjimenez Fixed typo
September 7, 20224 yr Author I debugged this issue further and can share the following: vault.enpassdb was initially 850 MB. I exported Enpass data to json and realized that 1 entry had a huge list of password history entries. I manually removed them. The json file size got reduced to 6MB. After I have imported the data from the modified json file, vault.enpassdb is now 400MB. I have 70 enpassattach files with a total size of 8MB. I turned off "Use Website icons" and "Check compromised passwords". Having those options turned off, Enpass is more responsive, but still not optimal. I also get the impression that while Enpass is syncing with WebDav, the main Enpass window is not responsive. Edited September 7, 20224 yr by Bob2
September 7, 20224 yr @Bob2 good find, I have the same in my exported passwords json file. This looks to me like syncing gone haywire, as I see the same few passwords over and over again. I will try your suggestion to delete all those historical passwords when I find the time @Abhishek DewanI smell a bug in the syncing code.
September 8, 20224 yr It seems to have worked, Enpass is working again and responsive. I did the following: Exported all passwords as json file. This was around 600MiB Removed all historical passwords. This reduced the file size to around 2MiB I disabled the sync for my vault, and then deleted the vault I created a new vault and imported the modified json file The Vault file is now 1.8MiB in size I enabled syncing via webdav to a new location so the old synced vault wouldn't interfere I then removed the vault from my Android phone, and synched from the new webdav location All is working fine after this process. I have yet to migrate my other machines. I hope the bug is found and squashed, I don't fancy doing this on a regular basis
September 8, 20224 yr @fjimenez thanks for the tip. I will try your solution over the weekend. So far no positioning from the Enpass team?
September 9, 20224 yr Hi @all Thank you for your patience while we investigated this concern. We were able to reproduce this issue on our end, and our dedicated team is working on a fix which will be implemented in the upcoming build. In the meantime, for Windows and Mac users, we have launched Enpass beta v6.8.3. You can try the beta version from here, and any feedback related to this issue would be appreciated.
September 15, 20224 yr Hello everybody. @Abhishek Dewan glad that at least a beta version was made available (windows and mac). For linux (which I use) unfortunately it's still at version 6.7.2 of Sep 07, 2021. Any predictions for linux?
September 15, 20224 yr The closest I have is a mac that's on OS 11.6, and testflight requires os 12 to install. My main systems are linux and android. I see an android beta but it doesn't look like it has the update in it. Can you give us a release date on these others platforms? As much as i've liked using enpass, this is critical to my business, and if i could find the export i'd be using bitwarden full time already.
September 16, 20224 yr Hi @joeldatabox, @dab I can certainly understand your disappointment in this matter. Unfortunately, I will not be able to share any exact ETA for when the new build/beta will be launched for other platforms. Rest assured that our development team is working hard to roll out the updates on all platforms as soon as possible. Any inconvenience caused is deeply regretted, and we appreciate your patience and support in the meantime.
December 6, 20223 yr Same at my side...: Hello! I am new to enpass. I like the desktop app (downloaded from enpass website, not MS Store) and iOS app, however I have a problem: I am transferring 850 records from splash ID. Import (csv) worked fine, now I need to name all user fields. This works (manually) fine. However, the desktop app (Windows 11, brand new system, app v6.8.4 (1167) gets very slow after editing about 20 - 30 records and freezes at some point ("no feedback"). Closing the app and reopening it does not help, sometimes even the re-login freezes. It then sometimes takes several minutes until the app starts again. But editing the entries remains unbearably slow. I can't use the app like this, unfortunately. I have the impression that it has to do with sync pausing, password checking and/or showing old passwords - but can't solve the problem on my side.... Any ideas?
December 7, 20223 yr Hi @MacGordon Welcome to the Enpass Forums. For troubleshooting purposes, create a manual backup of your Enpass data and then reinstall the app. If the issue persists, please share the below details with me and I'll have this further investigated for you - The cloud service you are using to synchronize your data. The number of Vaults and attachments you have in your Enpass app.
