May 27, 20233 yr Can Enpass Desktop version window be made 'sticky', so it stays on top of other windows..?
May 29, 20233 yr Hi @SRR You can enable the 'Always run Assistant in docked mode' setting from Enpass app Settings -> General. That way, Enpass Assistant will stay sticky on the screen and won't disappear when you click outside it. #SI-3365
July 7, 20233 yr I guess you can only stick the small windows which pops-up from the taskbar stick to your desktop, the big window seems not possible
July 9, 20233 yr Author On 7/7/2023 at 6:26 PM, AnakinCaesar said: I guess you can only stick the small windows which pops-up from the taskbar stick to your desktop, the big window seems not possible You are right. But this is not enough. The main-windows should 'stick' esply when we are trying to enter userid or password on some site and have to keep referring to the main window. These days most secure sights do not allow you to paste these values, so you have no option other than referring to the main window all the time
July 10, 20233 yr Hi @SRR I have taken note of your comments and promptly shared them with our dedicated development team for their consideration in future Enpass versions. We appreciate your patience during this time.
December 27, 20232 yr Author Any update on this, please. The absence of the 'Sticky' feature is v anoying at time.
