June 25, 20233 yr Purchased an Enpass Pro Lifetime Licence many years ago (2015/16'ish) for a LG G5+ which is now (and forever) at Android 7 vintage which is now becoming very limiting as security is now regarded as weak. Have purchased a Redmi Note 11 Pro+ 5G which updated itself from Android 11 to 13. Is it possible/permitted to transfer the Licence from the LG to the Redmi?
June 26, 20233 yr Just type in your email address you used for purchasing and you will unlock the pro version.
June 26, 20233 yr Hi @Boojum As mentioned by @AnakinCaesar, please register in the Enpass app on all your devices via the email address with which you purchased the license/ the license is associated. You can also refer to this link.
July 14, 20233 yr Author Many thanks for the good advice, all OK. Passing years and brain fade...app is of great value when taken into A&E asked what meds I take.
