August 10, 20233 yr In Enpass 6.9.0 stable builds, the websites favicon doesnt show anymore within inline autofill. This applies to both Windows (UWP) and Linux (RPM) and both extension versions 6.8.3 and 6.8.6 Tried with Chome, Firefox and Edge. Enpass extension 6.8.3 on Firefox and 6.8.6 in Chrome. Tried to disable and re-enable 'website icons' in Enpass and relaunch with no avail
August 11, 20233 yr Hi @Ivarson Kindly provide the precise operating system versions for both your Windows and Linux setups, as well as the versions of your browsers. I'd be more than willing to initiate an investigation into this matter for you.
August 12, 20233 yr I was about to start a topic on the same issue. This problem began right after updating from version 6.8.6 (1365) to version 6.9.0 (1465) of Enpass. Additional Information: Operating System: Windows 10 Pro 22H2 (Build 19045.3324) Enpass Version: 6.9.0 (1465) (website version) Browser Extensions: Chrome v115.0.5790.171 + Enpass Extension v6.8.6 Edge v115.0.1901.203 + Enpass Extension v6.8.6 Firefox v116.0.2 + Enpass Extension v6.8.3 Update: The issue was fixed in version 6.9.2 (1563) of Enpass. As noted in the release notes: “Fixed a problem with the browser extension’s inline menu misbehaving for Items with a custom icon in Enpass.” Edited January 20, 20251 yr by Send Zero The issue with favicons was fixed in a later version of Enpass
August 16, 20233 yr Hi @Send Zero I have forwarded this concern to our dedicated team and they are looking into this concern for you. As soon as I have more information on this matter, I will be sure to update this forum. Kindly bear with us until then. #SI-3439
August 17, 20233 yr Hi @Send Zero Upon a thorough investigation of this issue, we were able to reproduce the bug. Our development team is now working on fixing it as a priority, and a patch addressing this issue will be released soon. We appreciate your kind patience and cooperation in the interim.
