September 14, 20233 yr Hi! I ran into a little problem: In my vault I have a login item for iZotope and a login item for Native Instruments. Native Instruments decided to buy iZotope and they made the login page pretty much similiar. NI: https://auth.native-instruments.com/login?state=hKFo2SBuWEpLOVd5aE00STduVVF2SHR4eFN0LTY0U0xIZ2o0YqFupWxvZ2luo3RpZNkgTkNpSTRpRXZwQi1wblc0SlFuNG81OGx2NWdDNk1kOXmjY2lk2SBTT3BhbTZaTmJuT0tsc3VDNndVVDZPN1JLNm5nZ1pqZw&client=SOpam6ZNbnOKlsuC6wUT6O7RK6nggZjg&protocol=oauth2&audience=https%3A%2F%2Fapi.native-instruments.com&nonce=75472772fec9d6c1129fabeb2fc7ea61&lang=en&origin=Website&response_type=code&redirect_uri=https%3A%2F%2Fwww.native-instruments.com%2Fauth%2Fcallback&scope=openid email profile iZotope: https://auth.native-instruments.com/login?state=hKFo2SBtNF9KTXhDcXoxU3ZQSkxBMng0UVNaeWFnVjZyTkRNZKFupWxvZ2luo3RpZNkgQmg3Y25uakJhVnlTeUh6NWFBV24tRVNRa1puUlNsX2GjY2lk2SBBWlJ4dmt5ZzlVYm5BMGdMeTdSUVlGY1BjVm5LakFqRg&client=AZRxvkyg9UbnA0gLy7RQYFcPcVnKjAjF&protocol=oauth2&audience=https%3A%2F%2Fapi.native-instruments.com&nonce=a5acfff1841f295f74a5b9fe396352ac&origin=Website&response_type=code&redirect_uri=https%3A%2F%2Fwww.izotope.com%2Fauth%2Fcallback&scope=openid email profile So now every time I try to use autofill to log in on the iZotope homepage, Enpass thinks it is the Native Instruments login. I tried copying the links into each item, but Enpass is still not able to identify correctly which item it needs to use. After copying the links it looks like this: Is there any way to fix this ? Cheers, Karl Edited September 14, 20233 yr by KarlKaos
September 15, 20233 yr I suppose not, as both URLs are basically the same. There is no differenciation after TLD. You should try add the native URLs into each entry and see if it works, otherwise I do not know what would work
September 18, 20233 yr Hi @KarlKaos Enpass can automatically detect login forms and fillable fields, and suggests the corresponding Items stored in Enpass to fill those fields. If in case the URL of the webpages are same, the app may provide multiple suggestions to autofill. In this situation, do give the suggestion shared by @AnakinCaesar a try. If the problem remains, kindly share the version of the Enpass app, OS, Enpass Extension and browser you are using and I'll get this investigated for you.
