March 24, 20242 yr hi, i have a problem with the generated one time codes i tried to login in my account on nintendo and on playstation but both platform says the codes a not valid the only way to login is to use the backup codes. I tried to use the codes from my ios device they also not accepted Is there a bug in the latest releases? I'm on Windows 11 Enpass Client 6.9.5 (1639) Edited March 24, 20242 yr by ReneOtto
March 24, 20242 yr Author 33 minutes ago, AnakinCaesar said: Have you checked, that the time (zone) is correctly set? Where should the timezone set in enpass or where?
March 24, 20242 yr Author Now i tried direct login on ios it worked it might be a windows client problem.
March 24, 20242 yr Author 2 hours ago, AnakinCaesar said: Have you checked, that the time (zone) is correctly set? Windows Timezone is set to automatic
March 25, 20242 yr 17 hours ago, ReneOtto said: Windows Timezone is set to automatic That’s good. Have you compared both codes, Windows and iOS if they are the same? (Open both apps and have a look at the same time at both codes) if they are not, something is out of sync.
August 1, 20242 yr Was seeing this problem today. Windows 11. I'm in The Pacific time zone (GMT-8), but it's currently DST, so I'm *actually* GMT-7. I had Windows set to Pacific GMT-8, with "adjust for daylight saving time automatically" checked. My clock was correct. However, Enpass was generating incorrect OTP codes. I was only able to work around the problem by *unchecking* "adjust for daylight saving time automatically" and changing my time zone to Mountain time (GMT-7). It seems wrong that I should have to do that. My guess is that Enpass is not properly handling the "adjust for daylight saving time automatically" checkbox, and thought I was still GMT-8.
August 2, 20242 yr Thank you for sharing the details and your efforts in providing information. I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them. #SI-3927
