April 10, 20242 yr Hello, I'm on macOS with current Enpass. When I use the Global Hotkey for the Assistant, the Search Field has Focus for a mili Second, then looses it. Means I can't start typing to search. Can this be fixed somehow? Makes it hard to quickly copy a Password without using the Mouse. Regards, Bastian
April 10, 20242 yr We would appreciate it if you could provide the following details: Device OS version. Browser details. Enpass Version. Screenshots or screen recording, if available, would significantly aid our analysis. P.S. I suggest you use the latest version of the Enpass App and Extension
April 12, 20242 yr Author Device OS: Not involved Browser: Not involved Enpass Version: 6.9.5 MacOS Version: 14.4.1 Attached the dialog I talking about, there the Search field has the focus Problem. Dialog is called by the global hotkey.
April 12, 20242 yr Thank you, I've forwarded this issue to the Enpass technical team for investigation. I'll keep you updated as soon as I receive any updates from them. #SI-3777
August 28, 20242 yr Author Hello @Amandeep Kumar Are there any Updates? I found out, the focus Problem is only after Enpass runs for some times. After Restarts or Updates, it works some short time.
